FPGA Intellectual Property
6673 Discussions
error using Altera FIFO megafunction
Hello.
i've configured FIFO megafunc in such way as on img1
then i've tried to test its operating
in such way
module incomingCMD (); tri0 FULL, EMPTY, CLR, Q; tri0 CMD; tri0 USEDW; reg CLK, RDREQ, WRREQ; reg command; assign CMD = command; assign CLR = 0'b0; initial begin CLK <= 0'b1; RDREQ <= 0'b0; WRREQ <= 0'b1; end always begin # 10 CLK <= ~ CLK; end initial begin # 20 command <= 0'b1; # 30 command <= 0'b0; # 50 command <= 0'b1; # 70 command <= 0'b0; # 90 command <= 0'b1; # 20 command <= 0'b0; # 70 command <= 0'b1; # 10 command <= 0'b0; # 50 command <= 0'b1; # 80 command <= 0'b0; # 20 command <= 0'b1; # 40 WRREQ <= 0'b0; # 20 RDREQ <= 0'b1; end fifoCMD cmdSroradgeDevice ( .clock(CLK), .data(CMD), .rdreq(RDREQ), .sclr(CLR), .wrreq(WRREQ), .empty(EMPTY), .full(FULL), .q(Q), .usedw(USEDW)); endmodule
but i'got unexpected result my FIFO looks like dead. Sim on img2
Tell, me please my mistake...
And also one more question.. I'm going to write a controller SD Card R/W. SD uses CMD line both to get seriall commands and to response it. Thus i would like to know what is the best way to provide this relation. Am i right that trying to get responses in FIFO and than compare with command meanings ? Or there is some more comfortable way to do it?
The reason is ModelSim can't find or open "entity SCFIFO" from library altera_mf.
vsim rtl_work.fifo1 # vsim rtl_work.fifo1 # Loading rtl_work.fifo1 # ** Error: (vsim-3033) C:/StoreDev/Altera/incDevFIRBUp4_FIFO/fifo1.v(79): Instantiation of 'scfifo' failed. The design unit was not found. # Region: /fifo1 # Searched libraries: # C:\StoreDev\Altera\incDevFIRBUp4_FIFO\simulation\modelsim\rtl_work # Error loading design
I'm using ModelSim Starter 10c and QII 11.1. According to version.txt they are compatible, but i still have a problem...
How can i directly put a link to "entity SCFIFO" in ModelSim
As i understand i'm using Windows7 and there is some incompatibility with ModelSim because it cant use library. How can i solve this problem?
the fifo model should be in a library called altera_mf. are you using ModelSim-A(S)E?
and i haven't run into any sim issues on Windows 7
Yes, i'm using ModelSim Altera Starter E 10c
As i see there is some misunderstanding on my part during simulation megafunctions...
i tried to find the answer in
http://www.altera.com/literature/hb/qts/qts_qii53001.pdf
http://www.altera.com/literature/hb/qts/qts_qii53025.pdf
but there is still some misunderstandind
is it correct sequence of operations to sim projects with altera mf?
1. create QII proj
2. create megafunction
3. compile proj
4. open modelsim
5. create modelsim proj
6. add to proj megafunction wizard generated file
6. create hdl file where mf used
7. add through file properties to mf file library file (C:\Altera\11.1sp1\modelsim_ase\altera\verilog\src\altera_mf)
8. compile
9. simulate
in this way it works... is it correct??
i normally use NativeLink to generate a sim script and edit to taste, but your steps sound more involved than necessary
either try NativeLink or try to just vlog your design files and test bench then run vsim. the fifo should reference the altera_mf library on its own
