FPGA Intellectual Property
6671 Discussions
generating the Matrix_mult IP by using ALTERA_FP_MATRIX_MULT
I generated a matrix_mult IP by using ALTERA_FP_MATRIX_MULT. The system showed the following information.
Info: Saving generation log to /home/tan/temp/matrix_mu/unnamed/unnamed_generation.rpt
Info: Starting: Create block symbol file (.bsf)
Info: qsys-generate /home/tan/temp/matrix_mu/unnamed.qsys --block-symbol-file --output-directory=/home/tan/temp/matrix_mu/unnamed --family="Stratix V" --part=5SGXEA7H3F35C3
Progress: Loading matrix_mu/unnamed.qsys
Progress: Reading input file
Progress: Adding fp_matrix_mult_ii_0 [altera_fp_matrix_mult_ii 16.0]
Progress: Parameterizing module fp_matrix_mult_ii_0
Progress: Building connections
Progress: Parameterizing connections
Progress: Validating
Progress: Done reading input file
Info: qsys-generate succeeded.
Info: Finished: Create block symbol file (.bsf)
Info:
Info: Starting: Create HDL design files for synthesis
Info: qsys-generate /home/tan/temp/matrix_mu/unnamed.qsys --synthesis=VERILOG --output-directory=/home/tan/temp/matrix_mu/unnamed/synthesis --family="Stratix V" --part=5SGXEA7H3F35C3
Info: unnamed: Generating unnamed "unnamed" for QUARTUS_SYNTH
Error: fp_matrix_mult_ii_0: Error starting the process ([/home/tan/altera/16.0/quartus/../hls/bin/internal_matrixmult_helper, -march=altera, --RTL-only, --fp-relaxed, -o, matrix_mult, --device, Stratix V, --clang-arg, -generate-altera-ip, --fpc, -I., /home/tan/altera/16.0/ip/altera/dsp/altera_fp_matrix_mult_ii/matrix_mult.cpp]): Cannot run program "/home/tan/altera/16.0/quartus/../hls/bin/internal_matrixmult_helper" (in directory "/tmp/alt7282_5396898303674959013.dir/0001_fp_matrix_mult_ii_0_gen"): error=2, No such file or directory
Error: fp_matrix_mult_ii_0: IP geneneration failed at file discovery, please tell Altera
Error: can not find channel named "couldn't open "/tmp/alt7282_5396898303674959013.dir/0001_fp_matrix_mult_ii_0_gen//matrix_mult.prj/altera_fp_matrixmult_internal_hw.tcl": no such file or directory" while executing "read -nonewline $fd" (procedure "discover_files" line 5) invoked from within "discover_files $proxy_file_set $tmp_dir" (procedure "generate_all" line 15) invoked from within "generate_all $output_name QUARTUS_SYNTH" (procedure "generate_quartus_synth" line 2) invoked from within
"generate_quartus_synth unnamed_fp_matrix_mult_ii_0"
Info: fp_matrix_mult_ii_0: "unnamed" instantiated altera_fp_matrix_mult_ii "fp_matrix_mult_ii_0"
Info: unnamed: Done "unnamed" with 2 modules, 1 files
Error: qsys-generate failed with exit code 1: 3 Errors, 0 Warnings
Info: Finished: Create HDL design files for synthesis
I checked the contents in the directory /tmp/alt7282_5396898303674959013.dir, and found that it is empty. My computer environment is shown as follows:
OS: CentOS 6.5
FPGA tools: Quartus Prime Standard version 16.0.0 build 211
I login as root, and install the Quartus file, and run it. The user file folder is on the home directory.
Please tell me how to fix the error.
same problem here
AEsqu3
Same issue!
