FPGA Intellectual Property
6586 Discussions
help: the DDR2 controller works incorrectly
I use the DDR2 SDRAM Controller v9.1(not the high performance) and my memory is MT47H32M16cc-3. The parameters are set as follows:
clock speed 150MHz
Data bus width 16bit local width 32bit
Row 13bit Column 10bit Bank 3bit
CL 5
the DDR2 works correctly when I use the example driver which is generated by IP, but it works incorrectly sometimes when I replace the example driver by my own driver. My driver is very simple, just writes some data into ddr2, then reads back. But I compare the read back data with the write data, sometimes they are different. And I also find if I just write less then six data at once, there will be no errors. When I write more than six data, there will be errors sometimes. The attached files contain the SignalTap file and my own driver file. Does anyone can tell me where I am wrong?
Thanks a lot.
(Virus scan in progress ...)
What FPGA are you compiling for?
In the v10.1 controller there is a TCL script you have to run to make the appropriate IO and timing settings, did you run something like this?
Maybe it's related to the following issue:
http://www.altera.com/support/kdb/solutions/rd12132010_638.html
You're zip file seems to be empty, if you post the files I can take a look at them..
Grtz,
Olaf
--- Quote Start ---
Grtz,
Olaf
--- Quote End ---
thank you very much for your help. My FPGA is StratixII EP2S90F1020C3. I don't run any tcl for the project actually, I will try your suggestion. The attached file just contains one SignalTap file and one design file, not the whole project. I will change it.
Thanks again.
