FPGA Intellectual Property
6110 Discussions
how to set instance parameter for a qsys subsystem in quartus 18.0
I am trying to convert my project from quartus 16.1 to quartus 18.0 prime pro. I use qsys subsystems within a large qsys design.
I need to create several instances from the same qsys subsystem with different parameters. So I am using "Instance Parameter"
feature. After conversion to quartus 18.0, I don't find this instance parameters. How can I manage it in quartus 18.0 in Platform Designer?
Were you using Pro at 16.1? Subsystem instance parameters are not currently supported in Pro.
My project was written in Quartus16.1 standard. I want to convert it to Quartus 18.0 Prime Pro.
So as I said, it is supported in Standard. It's not currently supported in Pro.
