FPGA Intellectual Property
6356 Discussions
how to simulate the altclkctrl IP ?
zlan01
how to simulate the altclkctrl IP, which library should be included ? which file of the IP should be used ?
Kenny_Tan
Are you using the qsys instantiation? Or just normal instantiate?
Which version of Quartus that you were using? Std or Pro?
Each of them use different method.
zlan01
I am using Quartus-lite-18.1.0.625-windows to implement the project with max10, and when simulate the project, some files can not be found ,
will please tell me which library and files should be add to the simulation project? where I can find them ?
I am using modelsim to make the simulation .
Kenny_Tan
What you can do is use the native link simulation. you may refer to here
https://www.youtube.com/watch?v=PmVVXQchv2c
If you were using platform designer, this method will not work for you.
zlan01
thanks for your help very much,
Can I simulate the altclkctrl IP absolutely independent of the quartus ?
If I want to do so ,how can I do ?
and by the way I do not understand what is "using platform designer"? is that a customized developing board of intel fpga ?
Kenny_Tan
Platform design is a tools inside the quartus that use standart interconnect to connect your design. you can refer to https://www.youtube.com/watch?v=d43Pqc_IZpg
Yes, you can simulate the altclkctrl IP independent provided you know how to write the scripts. If you follow the https://www.youtube.com/watch?v=PmVVXQchv2c here, you will notice that the Quartus created a script automatically for you to do the simulation. You can make use of the scripts to do your  altclkctrl IP independent of Quartus. -> msim_setup.tcl
