FPGA Intellectual Property
6670 Discussions
how to use pci ip core
I use the pci ip core for 32bits target,and use the simple reference design in FPGA,
but I can't transactor data from or to the LPM RAM.
what's the error???
who can help me?
Hi Ling,
This is a very short description. Can you please tell the community a bit more about what you did and what you observed? Some details about the FPGA design, if the configuration worked well, if the card (if any) is plugged into a PC and if the PC detects the card, and so on. Then, maybe, we can help.
Harald
when I put the pci ip core into my project,there is a error.
Error: Node instance "pci_mt32_inst" instantiates undefined entity "pci_mt32"
when I use the 32bits target ip core .I can Full Compilation successfully .
but when connect to the PLX8112 to PCIE slot in the pc. I can't write or read .
thank you for your help ,harald
