FPGA Intellectual Property
6669 Discussions
i2c can't find core qsys
problem... Can't find i2c core in qsys. Is there this core by default there??/
If not. I have downloaded OpenCores I2C component. But question how can I add it to qsys???? Do I have create new component and ........ . Or there is easy way ??
Thank you.
Eduardas
No there is not i2c core in SOPC or Qsys.
You don't have to create a new component in Qsys, go to quartus installation directory, then ip directory, create a new directory with desired name and add the core to that directory or alternatively You can add it to ip->altera directory.
Otherwise copy the core directory wherever You want and add a new search path in Qsys settings.
--- Quote Start ---
--- Quote End ---
Which I2C file do You mean?
The only one , that seems to be relevant is:
\altera_12.1_177\ip\altera\sopc_builder_ip\altera_mp32\HAL\src\alt_iic.c
I added this path to IP search path in Qsys settings and refreshed the system.
But I2C QSys component did not appear in QSys Library ....
Or maybe I cannot find it , where in QSys Library should it appear ?
Or maybe alt_iic.c is not enough to create I2C QSys component?
.c or .h files have nothing common with qsys components...
What is the extension ( .* ) of needed I2C files which corresponds to I2C QSys component?
If successfully added, then in what section of QSys Library should I2C QSys component appear?
I added the whole directory \altera_12.1_177 to IP search path in Qsys settings and refreshed the system.
But no new QSys component appeared in QSys Library ...
Well, then create a new component by yourself, add design files and set the top module from the list.
I am not that advanced yet, that's why I'm looking for a ready-to-use I2C QSys component.
I'm sure it exists and I wonder why it is not so far included in QSys Library.
Altera did not make any i2c cores for Qsys. The component is available at Opencores, but You'll have to learn how to install it by Yourself.
Socrates does not seem able to read. Aphraton just wanted some help in knowing if there is a Qsys compliant I2C component, and said he was not that advanced yet. Snarky comments from Socrates don't seem useful in this context.
Anyway - Aphraton - you might like to check out here - http://www.alterawiki.com/wiki/i2c_(opencores). The I2C component has been updated to be Qsys compliant.
No, Socrates is able to read. He just hate lazy dummies asking to do a job for them. If You're not advanced enough - spend Your time researching and reading. Be advanced.
Do you know this core will work on Quartus 12.1 SP1 SOPC ?
--- Quote Start ---
Thank you.
Eduardas
--- Quote End ---
Create a folder named ip in your project directory which contains the .qsys file. Then add the i2c_opencores in the ip folder.
Refresh the system in Qsys to get rid of the error.
Anil
