FPGA Intellectual Property
6673 Discussions
ip compiler for pci-express user guide
on page 2.17 of the UG, it states: replace the endpoint application layer with your own design.
I expected to find a module with the Avalon MM signals, where I can connect my design,
There a a ton of files
I spend hours to browse through the files, but did not find the appropriate module,
Has anybody a hint for me ??
Can you elaborate the question.
Did you read the section 15 [related to the Testbench]. There you will find the BFM's using which you can write to the Application layer.
What are you trying to do?
