I'm working on a very simple verilog module that has a parameter for the width of an input signal. I'll be using "[WIDTH-1:0] nomenclature for register instantiations, for instance..
Two questions: 1) What will happen if they try to pass me a value of "0" ? 2) More importantly-- how can I "validate" the value is a Natural number (1 or greater) at compile time and throw an error if a value less than 1 is passed? thanks! ..daneLink Copied
1) Test it :-) and give answer. I think it not accepted by Quartus. 2) In VHDL, I use assertions. there may be an equivalent in Verilog. ++- Mark as New
Is it going to be a custom component in SOPC Builder? If it is, you can add ranges to generics in your hw.tcl file that will notify the user and stop him/her from generating the project if the value is outside the range.
--- Quote Start --- Hi, 1) Test it :-) and give answer. I think it not accepted by Quartus. 2) In VHDL, I use assertions. there may be an equivalent in Verilog. ++ --- Quote End --- 1) wiseguy .. :) I knew I could test it -- but that only yields results very particular to one software (Quartus), and moreover, one version of that software (I'm using v7.2) ... I was hoping for a more "Verilog Lanugage Rules" type answer... :) Anyways, QII v7.2 gives the following error: Error (10232): Verilog HDL error at ***v(**): index 1 cannot fall outside the declared range [-1:0] for vector "****" 2) Did some checking -- Verilog doesn't seem to support Assertions yet ... :( maybe we can hope for a future revision to include support.. --- Quote Start --- Is it going to be a custom component in SOPC Builder? If it is, you can add ranges to generics in your hw.tcl file that will notify the user and stop him/her from generating the project if the value is outside the range. --- Quote End --- Nope-- not using SOPC builder this time around .. no need for this project.. thanks though! ..dane
