Hello Everyone,
I am using Low Latency Ipcore to tranmist from 4 channels, I define these datas as constant arrays. When all 4 channel has the same array to transmit it works fine however when I change one of them to another data it effects all channels. (For example I am scoping channel 1 and change the data in channel 2, channel 1 noise level changes -becomes worse.) I couldnt find why? Any suggestions to find a solution? Any help will be appreciated. BestLink Copied
