FPGA Intellectual Property
6105 Discussions
missing .ipx file in 18.1 quartus
APPU_appu
@JohnT_Intel
Error: Missing file C:/intelfpga_pro/18.1/nios2eds/hw_library.iipx
Error: Missing file C:/intelfpga_pro/18.1/nios2eds/sw_library.iipx
Error: Missing file C:/intelfpga_pro/18.1/quartus/sopc_builder/hw_builtin.iipx
Error: Missing file C:/intelfpga_pro/18.1/quartus/sopc_builder/sw_builtin.iipx
SyafieqS
Hi Ashwi,
More information needed here on how did you encounter such error?
APPU_appu
Hi @SyafieqS
when i will try generate ip/ try to open the platform designer that time error will come
SyafieqS
Hi Ashwi,
Verify the .ipx file is there in the directory and try to check you environment variable if they are added for both quartus and nios2eds.
APPU_appu
@SyafieqS @Deshi_Intel @JohnT_Intel
I checked in folder .ipx is found, enviranomnet also path added but again we are facing same issue. can you please address this issue
