hi,
i would convert a verilog code to vhdl code , //code verilog always@(posedge iCLK or negedge iRST_N) begin if(!iRST_N) begin LUT_INDEX <= 0; mLCD_ST <= 0; mDLY <= 0; mLCD_Start <= 0; mLCD_DATA <= 0; mLCD_RS <= 0; end else begin ........ ----------------------------------------------------------------------- --vhdl code process(iCLK,iRST_N) variable var_mDLY : std_logic_vector(17 downto 0); begin if (( iCLK 'event and iCLK='1') or (iRST_N 'event and iRST_N='0')) then if(iRST_N='0') then LUT_INDEX <=(others =>'0'); mLCD_ST <=(others =>'0'); mDLY <=(others =>'0'); mLCD_Start <='0'; mLCD_DATA <=(others =>'0'); mLCD_RS <='0'; else ............ when i compile this error appear: Error (10628): VHDL error at LCD_TEST.vhd(61): can't implement register for two clock edges combined with a binary operator so if somebody have any solution ?Link Copied
The Verilog always block can't be translated line by line, the syntax for a synchronous process with asynchronous reset is somewhat different. In my opinion, it's more intuitive than the respective Verilog construct that uses the negedge keyword for a level sensitive condition. You can use the language templates in Quartus editor context menu to look up the correct VHDL syntax for common design constructs.
begin
if iRST_N='0' then
mLCD_Start <='0';
mLCD_RS <='0';
elsif iCLK 'event and iCLK='1' then -- you can also write rising_edge(iCLK)
end if;
end process;
thank's for your reply
the code compile correctly but there is no result in the LCD. because i would to creat a controller of LCD 16x2 in DE2 i don't know what the origine of problem ? may be this part of initilization of LCD. but i would to ask you i can't add the falling_edge(iRST_N)? because the verilog code he use always@(posedge iCLK or negedge iRST_N) begin if(!iRST_N) begin- Mark as New
As I said, negedge doesn't actually mean an edge sensitive condition in this place. VHDL is more exact in this respect.
There may be many reasons why the LCD controller code is not working. You didn't show the relevant parts of it. If you have a known working Verilog controller code, you don't need to translate it to VHDL. You can instantiate it as a component in your VHDL design- Mark as New
Thank you very much
i try a whole code and i use some component in verilog, after that i found the mistakes in my code. i would know if you have any idea for create a master who can read/write in LCD ,i try with this code i compiled with no error but no result in the LCD you can See both attached files
