hi,
hello everyone, now i'm debug a ethernet ip in stratixiigx kits, when i generate the ip core,i find the address ie 8 bit width,but it's user guide says the max address of mac control interface is 0x3FC,the 8 bit data can demonstrate the 0x3FC?why? another problem is when i use 100M ethernet,my system clock is 100MHz,it gernate the clk,ff_tx_clk,ff_rx_clk,I think the clk is 100MHz,but how can i config the ff_tx_clk,ff_rx_clk? expect someone help me,thankfulLink Copied
The address bus on an Avalon slave directly designates a register number. As the data bus is 32-bits wide, the address is shifted by two bits. Ie when you put 0x10 on the address bus, you are in fact accessing the register at address 0x40.
hi,i find you are more knowledgeable,you help to resolve many problems with ethernet ip core,thanks
