FPGA Intellectual Property
6595 Discussions
question about “ A10SOC as PCIE RC ”
JET60200
hello expert,
We plan to start an “ A10SOC PCIE RC” design,  while the peer side  PCIe EP is a "pcie subcard w/ (gen3x8)".   Our target is to run Linux System on this A10SOC (HPS),  and  use HPS ARM core to communicate with the PCIe EP  slave device.  A few question I'm not clear :
1)   to my understanding,  A10 FPGA‘s HIP could work as RC , to communicate with an external " EP Device",  is it correct ?     Thus my question is "How  could  A10SOC HPS(ARM  communicate to that external PCIE EP device directly ?" ,  to execute some heavy-loading data moving ,  such as Cypro Accelator or Encoding/Decoding  ?
we must ensure the throughput and data bandwidth is sufficient between  HPS and external PCIe EP device.  isthere any suggestion or reference design example ?
sth like below:
Arria10 SOC(RC)   to  PCIe EP  ( Crypto card ) :
|                        |    FPGA    |   HIP        |   EP device   |
|       HPS         |                  |<<===>> |                       |
Thanks a lot
Deshi_Intel
It's possible to use Arria 10 PCIe HIP as root complex but the reference design for it is limited as typically we promote FPGA for PCIe EndPoint application.
So far I can only find below A10 PCIe RC reference design using HPS but it's targeting till PCIe Gen2 x8 only.
Nevertheless, fell free to check it out.
dlim
JET60200
Thanks @Deshi_Intel  for quick response , Will check the details
best regards
Deshi_Intel
Alright. Good luck in your project development.
