FPGA Intellectual Property
6359 Discussions
"DCFIFO first written data: lost!"
AGaru1
Hi all.
I'm struggeling with a problem trying to write some datas into a DCFIFO.
The write signal (wrreq) is an output from a fsm like this:
    p_fifo_wr_fsm : process(wrclk, RST)
        begin
            if (RST = '1') then
                wr_fifo_fsm_st              <= ST_IDLE;
                data                <= '0';
                wrreq               <= '0';
            elsif rising_edge(wrclk) then
                if (ENABLE = '0') then
        data                <= '0';
        wrreq               <= '0';
                else
                    case wr_fifo_fsm_st is
                        when ST_IDLE =>
                            if ((IN1 = '1') AND (IN2 = '1'))then
        wr_fifo_fsm_st                <= ST_WR;
        data                <= DATAIN;
        wrreq               <= '1';
                            else
        data                <= '0';
        wrreq               <= '0';
                            end if;
The problem is: the first data written into the fifo is missing when I try to read it.
The first read report the second written data.
The fifo is "no show ahead".
KhaiChein_Y_Intel
Could you share the design QAR file, simulation result and testbench for investigation? To generate the QAR file, click on Project > Archive Project.
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
