Hi all.
I'm struggeling with a problem trying to write some datas into a DCFIFO.
The write signal (wrreq) is an output from a fsm like this:
p_fifo_wr_fsm : process(wrclk, RST)
begin
if (RST = '1') then
wr_fifo_fsm_st <= ST_IDLE;
data <= '0';
wrreq <= '0';
elsif rising_edge(wrclk) then
if (ENABLE = '0') then
data <= '0';
wrreq <= '0';
else
case wr_fifo_fsm_st is
when ST_IDLE =>
if ((IN1 = '1') AND (IN2 = '1'))then
wr_fifo_fsm_st <= ST_WR;
data <= DATAIN;
wrreq <= '1';
else
data <= '0';
wrreq <= '0';
end if;
The problem is: the first data written into the fifo is missing when I try to read it.
The first read report the second written data.
The fifo is "no show ahead".
Could you share the design QAR file, simulation result and testbench for investigation? To generate the QAR file, click on Project > Archive Project.
KhaiY
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
