FPGA Intellectual Property
6404 Discussions
"Floating point functions Intel FPGA IP" Division configuration produces wrong answers
sackettaj
So I'm trying to use the "floating point functions Intel FPGA IP" library to run floating point division calculations. This library can be found in quartus prime pro edition under:
ip catalog -> installed ip -> library -> basic functions -> arithmetic -> floating point functions intel FPGA IP
I'm running into a problem where the floating point division computations are wrong. It seems like the numbers are being rounded to powers of two. Like the exponent is being computed, but not the mantissa.
Here are screenshots of my setup, along with screenshots of a questa simulation of the results.
IP SetupIP SetupIP settings from the IP planner
Project + Testbench codeProject + Testbench code Project navigator and test bench.
The comment on line 32 is wrong, that a value is 300 in 32 bit float, according to questa and https://www.h-schmidt.net/FloatConverter/IEEE754.html
ResultResult
Questa Result.
a,b,q are in [radix-> "1 float 32"] format.
Worth noting, letting the simulation run for another 1000 ns doesn't help, the final value sits at that 4.0 value seemingly indefinitely.
More inputs/outputs
a = 8.0, b = 2.0 -> q = 4.0
a = 325.162, b = 12.51 -> q = 16.0
a = 120.0 b = 150.0 -> q = 1.0
a = -25 b = 8100.16 -> q = -0.00195313 = 0xbb000000
What's going on here? Am I using the IP core incorrectly? Any help would be appreciated.
Kshitij_Intel
I am sharing an example design for the division of single precision. Please go through it.
https://www.intel.com/content/www/us/en/docs/programmable/683750/20-1/floating-point-ip-cores-design-example-files.html
If you still face any issues, please let me know.
Thank you
Kshitij Goel
FvM
Valued Contributor III
the Stratix III altfp_div design example doesn't help because it's using legacy altfp IP rather than HLS based "Floating Point Functions Intel FPGA IP" available in recent Quartus versions.
The float divider is working correctly for me. You didn't however report the device family and performance settings used in your design.
Looks like latency of 20. Notice that the divider probably won't run at 500 MHz with this setting in real hardware, expect that the simulator doesn't care about timing violations.
I was however simulating synthesized IP instead of sim package, synthesized with latency 15 to run at 100 MHz on Arria 10. If there's an issue with the simulation package, I won't get aware of.
Best regards
Frank
Kshitij_Intel
Can you please share your project to look into this issue.
Thank you
Kshitij Goel
Kshitij_Intel
As we do not receive any response from you on the previous question that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
