FPGA Intellectual Property
singchul33
sung_chul
Hi-
Tools,    Quartus 18.1
In Internal Memory (RAM and ROM) User Guide.pdf,    <-FPGA
words is 16bit or 32bit?
Thinks
RichardTanSY_Altera
That will be 8-bit words of memory.
You can see this by opening the RAM IP in the IP catalog. Once the IP parameter editor GUI open, you will see "How many 8-bit words of memory?".
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
sung_chul
Hi Richard Tan
I have changed  job
I received  previous project(Quartus 18.1)
The original engineer retired from the company.
In following figure,
It says "262144 words."
You say words is 8 bit
So 40 x 8 x 262144 =  83,886,080
Is this memory 83,886,080 bits?
RichardTanSY_Altera
Which device are you using?
sung_chul
Hi Richard Tan
Arrir 10
10AX027H4F34I3SG
Thanks!
RichardTanSY_Altera
Let me rephrase my previous reply. By default , the bit of memory is set as 8 when you open the IP and you can change the number of bits in the 'q' output width.
Referring to the screenshot that you attached, you are setting 40 bits with 262144 words.
So the total memory bits will be 40 x 262144 = 10,485,760. You can verify it by checking compilation report. Fitter > Resource Usage Summary.
sung_chul
Hi Richard Tan
Thank you very much!
Sincerely
RichardTanSY_Altera
You're welcome. Do you need further help in regards to this case?
Richard Tan
RichardTanSY_Altera
I will assumed that my reply has answer your question. With that, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
