Hi Sir/Madam,
There is a pin(sim_ltssmstate[4:0]) of IP compiler PCIe in Cyclone V ,But I can't find in Cyclone IV.
Any help would be appreciate !
Ted.Gao
Hi Ted Gao,
There are some differences in the simulation PIPE interface between Cyclone IV and Cyclone V. And Yes, the sim_ltssmstate signal is not available for Cyclone IV as the user guide. However, for hardware debug, you can still find the ltssmstate[4:0] from the signal tap.
Regards -SK
For the PCIe AVMM interface, the ltssm signals are not exposed to the top layer. If this is essential for the design, you may manually pull it out from the lower layer.
Regards -SK
Hi Ted Gao,
By referring to the lower layer code, I found that the ltssm is connecting to the test_out bus if the test out width is set to 9 bits. Probably, you can try to use the lower 5 bits of test_out bus.
assign test_out_test_out = { pcie_internal_hip_lane_act[3:0], pcie_internal_hip_dl_ltssm[4:0] };
Regards -SK
I set this forum case to close-pending for now. The status will remain in this state for 15 calendar days, simply post a note in this forum and it will be reopened for further investigation.
