13:22:59 (lmgrd) -----------------------------------------------
13:22:59 (lmgrd) Please Note:
13:22:59 (lmgrd)
13:22:59 (lmgrd) This log is intended for debug purposes only.
13:22:59 (lmgrd) In order to capture accurate license
13:22:59 (lmgrd) usage data into an organized repository,
13:22:59 (lmgrd) please enable report logging. Use Flexera's
13:22:59 (lmgrd) software license administration solution,
13:22:59 (lmgrd) FlexNet Manager, to readily gain visibility
13:22:59 (lmgrd) into license usage data and to create
13:22:59 (lmgrd) insightful reports on critical information like
13:22:59 (lmgrd) license availability and usage. FlexNet Manager
13:22:59 (lmgrd) can be fully automated to run these reports on
13:22:59 (lmgrd) schedule and can be used to track license
13:22:59 (lmgrd) servers and usage across a heterogeneous
13:22:59 (lmgrd) network of servers including Windows NT, Linux
13:22:59 (lmgrd) and UNIX.
13:22:59 (lmgrd)
13:22:59 (lmgrd)
13:22:59 (lmgrd)
13:22:59 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:22:59 Jerusalem Standard Time
13:22:59 (lmgrd) pid 10988
13:22:59 (lmgrd) SLOG: Summary LOG statistics is enabled.
13:22:59 (lmgrd) Done rereading
13:22:59 (lmgrd) FlexNet Licensing (v11.16.4.0 build 252457 i86_n3) started on REM-PC-02 (IBM PC) (2/23/2023)
13:22:59 (lmgrd) Copyright (c) 1988-2019 Flexera. All Rights Reserved.
13:22:59 (lmgrd) World Wide Web: http://www.flexerasoftware.com
13:22:59 (lmgrd) License file(s): C:\LMTools\LR-111665_License.dat
13:22:59 (lmgrd) lmgrd tcp-port 28010
13:22:59 (lmgrd) (@lmgrd-SLOG@) ===============================================
13:22:59 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
13:22:59 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Feb 23 2023 13:22:59 Jerusalem Standard Time
13:22:59 (lmgrd) (@lmgrd-SLOG@) PID: 10988
13:22:59 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.16.4.0 build 252457 i86_n3 ( build 252457 (ipv6))
13:22:59 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
13:22:59 (lmgrd) (@lmgrd-SLOG@) Listening port: 28010
13:22:59 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
13:22:59 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
13:22:59 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
13:22:59 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\LMTools\LR-111665_License.dat -l C:\ProgramData\FLEXlm\lmgrd\debug.log -z -s
13:22:59 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\LMTools\LR-111665_License.dat
13:22:59 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
13:22:59 (lmgrd) Starting vendor daemons ...
13:22:59 (lmgrd) Started alterad (pid 3972)
13:22:59 (lmgrd) Started mgcld (pid 14728)
13:22:59 (alterad) FlexNet Licensing version v11.18.2.0 build 281478 x64_n6
13:22:59 (lmgrd)
13:22:59 (lmgrd)
13:22:59 (lmgrd)
13:22:59 (lmgrd)
13:22:59 (lmgrd) Unrecognized command-line switch "1"
13:22:59 (lmgrd)
13:22:59 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:22:59 (lmgrd) [-v] [-local]
13:22:59 (lmgrd) [-x lmdown|lmremove] [-help]
13:22:59 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:22:59 (lmgrd)
13:23:04 (lmgrd) mgcld exited with status 1 signal = 812
13:23:04 (lmgrd) Since this is an unknown status, license server
13:23:04 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:04 (lmgrd) REStarted mgcld (pid 10804)
13:23:04 (lmgrd) -----------------------------------------------
13:23:04 (lmgrd) Please Note:
13:23:04 (lmgrd)
13:23:04 (lmgrd) This log is intended for debug purposes only.
13:23:04 (lmgrd) In order to capture accurate license
13:23:04 (lmgrd) usage data into an organized repository,
13:23:04 (lmgrd) please enable report logging. Use Flexera's
13:23:04 (lmgrd) software license administration solution,
13:23:04 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:04 (lmgrd) into license usage data and to create
13:23:04 (lmgrd) insightful reports on critical information like
13:23:04 (lmgrd) license availability and usage. FlexNet Manager
13:23:04 (lmgrd) can be fully automated to run these reports on
13:23:04 (lmgrd) schedule and can be used to track license
13:23:04 (lmgrd) servers and usage across a heterogeneous
13:23:04 (lmgrd) network of servers including Windows NT, Linux
13:23:04 (lmgrd) and UNIX.
13:23:04 (lmgrd)
13:23:04 (lmgrd)
13:23:04 (lmgrd)
13:23:04 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:04 Jerusalem Standard Time
13:23:04 (lmgrd) Unrecognized command-line switch "1"
13:23:04 (lmgrd)
13:23:04 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:04 (lmgrd) [-v] [-local]
13:23:04 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:04 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:04 (lmgrd)
13:23:05 (alterad) lmgrd version 11.16, alterad version 11.18
13:23:05 (alterad) SLOG: Summary LOG statistics is enabled.
13:23:05 (alterad) SLOG: FNPLS-INTERNAL-CKPT1
13:23:05 (alterad) SLOG: VM Status: 0
13:23:05 (alterad) SLOG: FNPLS-INTERNAL-CKPT5
13:23:05 (alterad) SLOG: TPM Status: 0
13:23:05 (alterad) SLOG: FNPLS-INTERNAL-CKPT6
13:23:05 (alterad) Server started on REM-PC-02 for:
13:23:05 (alterad) ip_base (consisting of: 6AF7_0034
13:23:05 (alterad) 6AF7_00D8 6AF7_0014)
13:23:05 (alterad) sw_pe (consisting of: quartus_nonvolatile_encryption
13:23:05 (alterad) quartus_pro quartus) maxplus2verilog
13:23:05 (alterad) maxplus2vhdl quartus_nonvolatile_encryption maxplus2
13:23:05 (alterad) EXTERNAL FILTERS are OFF
13:23:05 (lmgrd) mgcld exited with status 1 signal = 836
13:23:05 (lmgrd) Since this is an unknown status, license server
13:23:05 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:05 (lmgrd) REStarted mgcld (pid 992)
13:23:05 (lmgrd) alterad using TCP-port 60705
13:23:05 (alterad) SLOG: Statistics Log Frequency is 240 minute(s).
13:23:05 (alterad) SLOG: TS update poll interval is 600 seconds.
13:23:05 (alterad) SLOG: Activation borrow reclaim percentage is 0.
13:23:05 (alterad) (@alterad-SLOG@) ===============================================
13:23:05 (alterad) (@alterad-SLOG@) === Vendor Daemon ===
13:23:05 (alterad) (@alterad-SLOG@) Vendor daemon: alterad
13:23:05 (alterad) (@alterad-SLOG@) Start-Date: Thu Feb 23 2023 13:23:05 Jerusalem Standard Time
13:23:05 (alterad) (@alterad-SLOG@) PID: 3972
13:23:05 (alterad) (@alterad-SLOG@) VD Version: v11.18.2.0 build 281478 x64_n6 ( build 281478 (ipv6))
13:23:05 (alterad) (@alterad-SLOG@) === Startup/Restart Info ===
13:23:05 (alterad) (@alterad-SLOG@) Options file used: None
13:23:05 (alterad) (@alterad-SLOG@) Is vendor daemon a CVD: No
13:23:05 (alterad) (@alterad-SLOG@) Is FlexNet Licensing Service installed and compatible: No
13:23:05 (alterad) (@alterad-SLOG@) FlexNet Licensing Service Version: -NA-
13:23:05 (alterad) (@alterad-SLOG@) Is TS accessed: No
13:23:05 (alterad) (@alterad-SLOG@) TS access time: -NA-
13:23:05 (alterad) (@alterad-SLOG@) Number of VD restarts since LS startup: 0
13:23:05 (alterad) (@alterad-SLOG@) === Network Info ===
13:23:05 (alterad) (@alterad-SLOG@) Listening port: 60705
13:23:05 (alterad) (@alterad-SLOG@) Daemon select timeout (in seconds): 1
13:23:05 (alterad) (@alterad-SLOG@) === Host Info ===
13:23:05 (alterad) (@alterad-SLOG@) Host used in license file: REM-PC-02
13:23:05 (alterad) (@alterad-SLOG@) HostID node-locked in license file: a8a15949bae2
13:23:05 (alterad) (@alterad-SLOG@) HostID of the License Server: "a8a15949bae2 54ace1728a0a 5410cce1210b"
13:23:05 (alterad) (@alterad-SLOG@) Running on Hypervisor: Not determined - treat as Physical
13:23:05 (alterad) TCP_NODELAY NOT enabled
13:23:05 (alterad) ---------------------------------------------
13:23:05 (lmgrd) Please Note:
13:23:05 (lmgrd)
13:23:05 (lmgrd) This log is intended for debug purposes only.
13:23:05 (lmgrd) In order to capture accurate license
13:23:05 (lmgrd) usage data into an organized repository,
13:23:05 (lmgrd) please enable report logging. Use Flexera's
13:23:05 (lmgrd) software license administration solution,
13:23:05 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:05 (lmgrd) into license usage data and to create
13:23:05 (lmgrd) insightful reports on critical information like
13:23:05 (lmgrd) license availability and usage. FlexNet Manager
13:23:05 (lmgrd) can be fully automated to run these reports on
13:23:05 (lmgrd) schedule and can be used to track license
13:23:05 (lmgrd) servers and usage across a heterogeneous
13:23:05 (lmgrd) network of servers including Windows NT, Linux
13:23:05 (lmgrd) and UNIX.
13:23:05 (lmgrd)
s port listener thread (DPLT)
13:23:05 (lmgrd) -----------------------------------------------
13:23:05 (lmgrd)
13:23:05 (lmgrd)
13:23:05 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:05 Jerusalem Standard Time
13:23:05 (alteradUnrecognized command-line switch "1"
13:23:05 (lmgrd) ics output thread (DRQT)
13:23:05 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:05 (lmgrd) [-v] [-local]
13:23:05 (lmgrd) [-x lmdown|lmremove] [-help]
DPLT: running
13:23:05 (lmgrd)
13:23:05 (alterad) DRQT: running
13:23:05 (alterad) DPLT: waiting for logger to connect
13:23:10 (lmgrd) mgcld exited with status 1 signal = 844
13:23:10 (lmgrd) Since this is an unknown status, license server
13:23:10 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:10 (lmgrd) REStarted mgcld (pid 1144)
13:23:10 (lmgrd) -----------------------------------------------
13:23:10 (lmgrd) Please Note:
13:23:10 (lmgrd)
13:23:10 (lmgrd) This log is intended for debug purposes only.
13:23:10 (lmgrd) In order to capture accurate license
13:23:10 (lmgrd) usage data into an organized repository,
13:23:10 (lmgrd) please enable report logging. Use Flexera's
13:23:10 (lmgrd) software license administration solution,
13:23:10 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:10 (lmgrd) into license usage data and to create
13:23:10 (lmgrd) insightful reports on critical information like
13:23:10 (lmgrd) license availability and usage. FlexNet Manager
13:23:10 (lmgrd) can be fully automated to run these reports on
13:23:10 (lmgrd) schedule and can be used to track license
13:23:10 (lmgrd) servers and usage across a heterogeneous
13:23:10 (lmgrd) network of servers including Windows NT, Linux
13:23:10 (lmgrd) and UNIX.
13:23:10 (lmgrd)
13:23:10 (lmgrd)
13:23:10 (lmgrd)
13:23:10 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:10 Jerusalem Standard Time
13:23:10 (lmgrd) Unrecognized command-line switch "1"
13:23:10 (lmgrd)
13:23:10 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:10 (lmgrd) [-v] [-local]
13:23:10 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:10 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:10 (lmgrd)
13:23:15 (lmgrd) mgcld exited with status 1 signal = 864
13:23:15 (lmgrd) Since this is an unknown status, license server
13:23:15 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:15 (lmgrd) REStarted mgcld (pid 15300)
13:23:15 (lmgrd) -----------------------------------------------
13:23:15 (lmgrd) Please Note:
13:23:15 (lmgrd)
13:23:15 (lmgrd) This log is intended for debug purposes only.
13:23:15 (lmgrd) In order to capture accurate license
13:23:15 (lmgrd) usage data into an organized repository,
13:23:15 (lmgrd) please enable report logging. Use Flexera's
13:23:15 (lmgrd) software license administration solution,
13:23:15 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:15 (lmgrd) into license usage data and to create
13:23:15 (lmgrd) insightful reports on critical information like
13:23:15 (lmgrd) license availability and usage. FlexNet Manager
13:23:15 (lmgrd) can be fully automated to run these reports on
13:23:15 (lmgrd) schedule and can be used to track license
13:23:15 (lmgrd) servers and usage across a heterogeneous
13:23:15 (lmgrd) network of servers including Windows NT, Linux
13:23:15 (lmgrd) and UNIX.
13:23:15 (lmgrd)
13:23:15 (lmgrd)
13:23:15 (lmgrd)
13:23:15 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:15 Jerusalem Standard Time
13:23:15 (lmgrd) Unrecognized command-line switch "1"
13:23:15 (lmgrd)
13:23:15 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:15 (lmgrd) [-v] [-local]
13:23:15 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:15 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:15 (lmgrd)
13:23:20 (lmgrd) mgcld exited with status 1 signal = 872
13:23:20 (lmgrd) Since this is an unknown status, license server
13:23:20 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:20 (lmgrd) REStarted mgcld (pid 14900)
13:23:20 (lmgrd) -----------------------------------------------
13:23:20 (lmgrd) Please Note:
13:23:20 (lmgrd)
13:23:20 (lmgrd) This log is intended for debug purposes only.
13:23:20 (lmgrd) In order to capture accurate license
13:23:20 (lmgrd) usage data into an organized repository,
13:23:20 (lmgrd) please enable report logging. Use Flexera's
13:23:20 (lmgrd) software license administration solution,
13:23:20 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:20 (lmgrd) into license usage data and to create
13:23:20 (lmgrd) insightful reports on critical information like
13:23:20 (lmgrd) license availability and usage. FlexNet Manager
13:23:20 (lmgrd) can be fully automated to run these reports on
13:23:20 (lmgrd) schedule and can be used to track license
13:23:20 (lmgrd) servers and usage across a heterogeneous
13:23:20 (lmgrd) network of servers including Windows NT, Linux
13:23:20 (lmgrd) and UNIX.
13:23:20 (lmgrd)
13:23:20 (lmgrd)
13:23:20 (lmgrd)
13:23:20 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:20 Jerusalem Standard Time
13:23:20 (lmgrd) Unrecognized command-line switch "1"
13:23:20 (lmgrd)
13:23:20 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:20 (lmgrd) [-v] [-local]
13:23:20 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:20 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:20 (lmgrd)
13:23:25 (lmgrd) mgcld exited with status 1 signal = 876
13:23:25 (lmgrd) Since this is an unknown status, license server
13:23:25 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:25 (lmgrd) REStarted mgcld (pid 12532)
13:23:25 (lmgrd) -----------------------------------------------
13:23:25 (lmgrd) Please Note:
13:23:25 (lmgrd)
13:23:25 (lmgrd) This log is intended for debug purposes only.
13:23:25 (lmgrd) In order to capture accurate license
13:23:25 (lmgrd) usage data into an organized repository,
13:23:25 (lmgrd) please enable report logging. Use Flexera's
13:23:25 (lmgrd) software license administration solution,
13:23:25 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:25 (lmgrd) into license usage data and to create
13:23:25 (lmgrd) insightful reports on critical information like
13:23:25 (lmgrd) license availability and usage. FlexNet Manager
13:23:25 (lmgrd) can be fully automated to run these reports on
13:23:25 (lmgrd) schedule and can be used to track license
13:23:25 (lmgrd) servers and usage across a heterogeneous
13:23:25 (lmgrd) network of servers including Windows NT, Linux
13:23:25 (lmgrd) and UNIX.
13:23:25 (lmgrd)
13:23:25 (lmgrd)
13:23:25 (lmgrd)
13:23:25 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:25 Jerusalem Standard Time
13:23:25 (lmgrd) Unrecognized command-line switch "1"
13:23:25 (lmgrd)
13:23:25 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:25 (lmgrd) [-v] [-local]
13:23:25 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:25 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:25 (lmgrd)
13:23:30 (lmgrd) mgcld exited with status 1 signal = 856
13:23:30 (lmgrd) Since this is an unknown status, license server
13:23:30 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:30 (lmgrd) REStarted mgcld (pid 11496)
13:23:30 (lmgrd) -----------------------------------------------
13:23:30 (lmgrd) Please Note:
13:23:30 (lmgrd)
13:23:30 (lmgrd) This log is intended for debug purposes only.
13:23:30 (lmgrd) In order to capture accurate license
13:23:30 (lmgrd) usage data into an organized repository,
13:23:30 (lmgrd) please enable report logging. Use Flexera's
13:23:30 (lmgrd) software license administration solution,
13:23:30 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:30 (lmgrd) into license usage data and to create
13:23:30 (lmgrd) insightful reports on critical information like
13:23:30 (lmgrd) license availability and usage. FlexNet Manager
13:23:30 (lmgrd) can be fully automated to run these reports on
13:23:30 (lmgrd) schedule and can be used to track license
13:23:30 (lmgrd) servers and usage across a heterogeneous
13:23:30 (lmgrd) network of servers including Windows NT, Linux
13:23:30 (lmgrd) and UNIX.
13:23:30 (lmgrd)
13:23:30 (lmgrd)
13:23:30 (lmgrd)
13:23:30 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:30 Jerusalem Standard Time
13:23:30 (lmgrd) Unrecognized command-line switch "1"
13:23:30 (lmgrd)
13:23:30 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:30 (lmgrd) [-v] [-local]
13:23:30 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:30 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:30 (lmgrd)
13:23:35 (lmgrd) mgcld exited with status 1 signal = 556
13:23:35 (lmgrd) Since this is an unknown status, license server
13:23:35 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:35 (lmgrd) REStarted mgcld (pid 17368)
13:23:35 (lmgrd) -----------------------------------------------
13:23:35 (lmgrd) Please Note:
13:23:35 (lmgrd)
13:23:35 (lmgrd) This log is intended for debug purposes only.
13:23:35 (lmgrd) In order to capture accurate license
13:23:35 (lmgrd) usage data into an organized repository,
13:23:35 (lmgrd) please enable report logging. Use Flexera's
13:23:35 (lmgrd) software license administration solution,
13:23:35 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:35 (lmgrd) into license usage data and to create
13:23:35 (lmgrd) insightful reports on critical information like
13:23:35 (lmgrd) license availability and usage. FlexNet Manager
13:23:35 (lmgrd) can be fully automated to run these reports on
13:23:35 (lmgrd) schedule and can be used to track license
13:23:35 (lmgrd) servers and usage across a heterogeneous
13:23:35 (lmgrd) network of servers including Windows NT, Linux
13:23:35 (lmgrd) and UNIX.
13:23:35 (lmgrd)
13:23:35 (lmgrd)
13:23:35 (lmgrd)
13:23:35 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:35 Jerusalem Standard Time
13:23:35 (lmgrd) Unrecognized command-line switch "1"
13:23:35 (lmgrd)
13:23:35 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:35 (lmgrd) [-v] [-local]
13:23:35 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:35 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:35 (lmgrd)
13:23:40 (lmgrd) mgcld exited with status 1 signal = 788
13:23:40 (lmgrd) Since this is an unknown status, license server
13:23:40 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:40 (lmgrd) REStarted mgcld (pid 1600)
13:23:40 (lmgrd) -----------------------------------------------
13:23:40 (lmgrd) Please Note:
13:23:40 (lmgrd)
13:23:40 (lmgrd) This log is intended for debug purposes only.
13:23:40 (lmgrd) In order to capture accurate license
13:23:40 (lmgrd) usage data into an organized repository,
13:23:40 (lmgrd) please enable report logging. Use Flexera's
13:23:40 (lmgrd) software license administration solution,
13:23:40 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:40 (lmgrd) into license usage data and to create
13:23:40 (lmgrd) insightful reports on critical information like
13:23:40 (lmgrd) license availability and usage. FlexNet Manager
13:23:40 (lmgrd) can be fully automated to run these reports on
13:23:40 (lmgrd) schedule and can be used to track license
13:23:40 (lmgrd) servers and usage across a heterogeneous
13:23:40 (lmgrd) network of servers including Windows NT, Linux
13:23:40 (lmgrd) and UNIX.
13:23:40 (lmgrd)
13:23:40 (lmgrd)
13:23:40 (lmgrd)
13:23:40 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:40 Jerusalem Standard Time
13:23:40 (lmgrd) Unrecognized command-line switch "1"
13:23:40 (lmgrd)
13:23:40 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:40 (lmgrd) [-v] [-local]
13:23:40 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:40 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:40 (lmgrd)
13:23:45 (lmgrd) mgcld exited with status 1 signal = 896
13:23:45 (lmgrd) Since this is an unknown status, license server
13:23:45 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
13:23:45 (lmgrd) REStarted mgcld (pid 12948)
13:23:45 (lmgrd) -----------------------------------------------
13:23:45 (lmgrd) Please Note:
13:23:45 (lmgrd)
13:23:45 (lmgrd) This log is intended for debug purposes only.
13:23:45 (lmgrd) In order to capture accurate license
13:23:45 (lmgrd) usage data into an organized repository,
13:23:45 (lmgrd) please enable report logging. Use Flexera's
13:23:45 (lmgrd) software license administration solution,
13:23:45 (lmgrd) FlexNet Manager, to readily gain visibility
13:23:45 (lmgrd) into license usage data and to create
13:23:45 (lmgrd) insightful reports on critical information like
13:23:45 (lmgrd) license availability and usage. FlexNet Manager
13:23:45 (lmgrd) can be fully automated to run these reports on
13:23:45 (lmgrd) schedule and can be used to track license
13:23:45 (lmgrd) servers and usage across a heterogeneous
13:23:45 (lmgrd) network of servers including Windows NT, Linux
13:23:45 (lmgrd) and UNIX.
13:23:45 (lmgrd)
13:23:45 (lmgrd)
13:23:45 (lmgrd)
13:23:45 (lmgrd) Server's System Date and Time: Thu Feb 23 2023 13:23:45 Jerusalem Standard Time
13:23:45 (lmgrd) Unrecognized command-line switch "1"
13:23:45 (lmgrd)
13:23:45 (lmgrd) usage: lmgrd [-l [+]debug_log_path] [-2 -p] [-z] [-c license_file_list]
13:23:45 (lmgrd) [-v] [-local]
13:23:45 (lmgrd) [-x lmdown|lmremove] [-help]
13:23:45 (lmgrd) Use -l option before other options to log all debugging information to debug_log_path.
13:23:45 (lmgrd)
13:23:50 (lmgrd) mgcld exited with status 1 signal = 904
13:23:50 (lmgrd) Please correct problem and restart daemons
