FPGA Intellectual Property
6343 Discussions
timing questions -false path for the experts
I have a design that has value in it that define the code behavior, let call them:
config_reg
table_of_vaule
1. because of the nature of those things, they are deep in the design.
2. those values are being configured using 25Mhz clock
3. values are used using a 100Mhz clock.
I run a set_flase_path :
set_false_path -from [get_keepers {config_reg}]
set_false_path -to[get_keepers {config_reg}]
make sure than when I write and read I hold the values10 clocks, make sure it sticks.
Another code run on a different 100Mhz, used config_reg(0) to branch.
Assuming values at config_reg are stable does the set_flase_path has any damaging effect?
@100Mhz
if(a=1 and config_reg(0)) then
what about that:
@100Mhz
if(a=1 and config_reg(sel)) then
where sel and a are 100Mhx values with NO false_path on them.
thanks
You have false_path'ed config reg, so the fitter is free to place them wherever it likes, and any timing will ignore config_reg. Are you sure you want to do this? it could be violating timing and increase the chance of a metastable event when it changes.
--- Quote Start ---
--- Quote End ---
We can assume config_reg will not change...
when i do write to it, i am making sure i hold values long enough,
i also read back to validate.
Can we assume a<=config_reg will be valid, asume config_reg does not change?
--- Quote Start ---
--- Quote End ---
For clock crossing there are two scenarios:
If any signal transition from clk1 domain to clk2 domain is designed to be sampled after several clocks periods on clk2 then it is safe. This implies slow signals
For faster signals (as well as short pulses) , above cannot be done and a fifo (or handshake) solution is needed.
Even if config reg don't change?
no change means no worry at all
but remember you are sampling to (a) which will change. So is that change going to affect next path
So? It same?
Does a has the value?
Does the above conditions I wrote will work?
If you mean conf_reg is constant then that is not a timing path to reg (a).
Now if reg (a) is on slow clk you are sampling a constant (no problem) and (a) will acquire new value. If this is passed to fast clock then this path from (a) must be allowed to settle.
You need to explain clocks used in your request of a <= conf_reg
--- Quote Start ---
--- Quote End ---
I explained it before, but ill do it again:
config_reg
*making sure that when I write and read I hold the values 10 clocks (or more), make sure it sticks.
@100Mhz
what about that:
@100Mhz
I read your first post and re-read it but you are not explaining the clocking scheme around (a).
I understand you are clocking the register conf_reg with 25MHz.
But what about register (a)? is it on 25MHz or 100MHz?
From your statemet "if a=1 and conf_reg(0)" I know it is on clock 100MHz thereafter
@100Mhz
"a" and "sel" are at 100Mhz, and config_reg is 25Mhz, granting not to change.
--- Quote Start ---
@100Mhz
--- Quote End ---
Ok so reg(a) is clocked by 100MHz, so is reg(sel) but conf_reg is clocked by 25MHz.
path 1) The path from conf_reg can be made false, but not the one (to) conf_reg, and
path 2) provided the path on clock 100MHz from (a) to next register is given enough time to settle since (a) output could change anytime an may violate clock 100MHz.
If you are not sure insert two registers on clock 100MHz just before (a) register.
The other option is to use en1 on reg(a) and en2 on next register and control delay of sampling between en1 & en2
reg "a" will sample "config_reg" once at 100Mhz in one of the steps on the state machine....
values from register "a" are not set to false path....
process(clk100mhz)
beginif (rising_edge(clk100mhz)) then
if (sig_from_another_100mhz_process='1') then
a<=config_reg;
a_was_set<='1';
else
a_was_set<='0';
end if;
if (a_was_set='1') then
b<=a;
end if;
end if;
end process;
b and a should be able to hold the correct value of config_Reg, assuming config_reg does ***not*** changes
--- Quote Start ---
--- Quote End ---
just to correct myself. if conf_reg is constant then there is no problem. you can set false path from it an ignore my other notes
--- Quote Start ---
--- Quote End ---
is not define as a "constant" in vhdl, however.... it will not change...
--- Quote Start ---
--- Quote End ---
so it is set early well before design starts using it even if (a) samples it from start the design is idle. That is ok
thank you.
what about :
a<=config_reg(sel);
where a,sel are 100Mhz ?
--- Quote Start ---
thank you.
what about :
a<=config_reg(sel);
--- Quote End ---
sel being generated in clk 100MHz domain is ok.
