FPGA Intellectual Property
6673 Discussions
usage advanced blocks FFT blocks in project Standart blockset
1) I want to build a project using the HDL import, so I chose standart blockset.
2) I saw a working example of the combination of Standart and Advanced blockset - adapted_ad9856.mdl, and I want use blocks FFT and Cordic from advanced blockset. But errors has occuring:
http://www.alteraforum.com/forum/attachment.php?attachmentid=10509&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=10508&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=10510&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=10511&stc=1
How I can implement input complex signal from Standart blockSet?
Maybe there's HDL imports in the Advanced blockset?
matlab file .mdl http://ge.tt/4fvtvqe2
Hi all! I figured out the problem posed.
Model:https://www.alteraforum.com/forum/attachment.php?attachmentid=10516
Input func:https://www.alteraforum.com/forum/attachment.php?attachmentid=10514
Furrier coeff:https://www.alteraforum.com/forum/attachment.php?attachmentid=10515
OutputFunc:https://www.alteraforum.com/forum/attachment.php?attachmentid=10517
Now, I want to know: How can I reduce the number of Fourier coefficients.
I want to make the Fourier transform of the period of 8192 points. But I do not want all of 8192 coefficients , I will have enough and no more than 20.
Matlab file: http://ge.tt/1vjrite2
I solved all problems =) model works =)
I want to make the Fourier transform of the period of 8192 points. But I do not want all the 8192 coefficients,
How i can get only first 20 and usage only 20 for retriving function, then improve performance and minimize the cost of memory for storing coefficients.
Work model http://ge.tt/1vjrite2 - adaptedModelWithCordic.mdl
