FPGA Intellectual Property
6670 Discussions
variable length shift register needed
i need a shift register with variable length, i can't find it in dsp builder.
I have never used DSP Builder but what you described is often called a barrelshifter. Perhaps it is called that in DSP Builder.
In verilog you can create a barrelshift with code like this:
assign c = b << a; // right shift by variable length
assign f = e >> d; // left shift by variable length
The code above will be very slow since it's combinational. You can either pipeline the operation or use a multiplier block to do the same thing.
