Good evening to all,
I installed Quartus web edition a few weeks ago, now I've done the architecture and generate the file. sof;'m going to program the card but the program throws the following warning: "contains one or more time-limited support megafunctions That the OpenCores Plus That feature will not work after the hardware evaluation time expires. messagges reffering to the evaluation time window for details " This to me implies a malfunction of the circuit? ThanksLink Copied
no malfunction, you are just using a MegaCore function in your design that requires a license to operate in standard (non-OpenCore Plus) mode
--- Quote Start --- no malfunction, you are just using a MegaCore function in your design that requires a license to operate in standard (non-OpenCore Plus) mode --- Quote End --- my architecture contains the following elements:
- nios2processor
- interval timere
- flash memory interface ( cfi )
- jtag uart
- epcs flash controller
- avalon tristate
- on chip memory
Nios II/e is free (in 9.1+), the other two are licenced
Topic Options
