FPGA Intellectual Property
6673 Discussions
why fft core's output is conjugate
Dear all,
When I using quartu12.0's fft megacore IP, I found such problems:
chose variable streaming and natural order for both input and output order, set ifft, make sink real = impulse, sink_imag =0, 1024 point, the ifft output from the simulation shows that the (source_real + 1j*soure_imag) is the conjugate of the ideal result from matlab. Please help me. Thank you very much.
And the result is caputured as follows:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6874
It could be your understanding of ofrequency sense is wrong between matlab model and ifft core.
You got cos waveform on real ifft output and -sin waveform on imag ifft output.
This means your so called impulse is one nonzero sample at a negative frequency location i.e. after midpoint of 1024 (well further from sample 512) .
So in which sample did you put that impulse?
