FPGA Intellectual Property
6260 Discussions
why my a10 project av-mm-dma for pcie ip resource utilization don't like ug described?
MWen01
Intel ug described pcie av-mm-dma resource utilization:
In my project,pcie ip configured gen2 x4 128bit,125Mhz,as follow:
quartus fitter resource utilization:
Thanks!
Nathan_R_Intel
Hie,
Could you advice if the ALM count was based compilation of the Example Design generated using the "Generate Example Design".
Nathan
