5703 Discussions
使用Cyclone V 作为控制器件是否具有 PR_IP_core 功能,用于对Strarix10进行部分重配置
smeng12
Partner
JohnT_Intel
I wouldn't recommend using the IP with hashtag "Cyclone V" on Stratix 10. I would recommend you to use the IP without the hashtag.
smeng12
Partner
It‘s not using CycloneV's IP on Stratix. Let me say it again . I want to ask "If Cyclone V  device is used as the configuration device of Strarix10 device, does Cyclone V  have the function of  PR_IP_core" thank you.
JohnT_Intel
Just to reclarify, you would like to use Cyclone V to performed Partial Reconfiguration on Stratix 10 device? If yes, then you can implement this without any issue by using the PR IP set as external host.
DXu2
Partner
1 客户的疑问:使用C5 去给S10 做PR,方案是否可行?
Partial Reconfiguration Solutions IPUser Guide 写的:
Note: The Intel Arria 10 Partial Reconfiguration Controller IP core supports both internal and
external host configurations. The current version of the Intel Stratix 10 Partial
Reconfiguration Controller IP core supports only internal host configuration?
2 如果在C5 上可行,C5 有对应的那个IP去使用?
JohnT_Intel
