5785 Discussions
在C10GX中的DDR3 IP avalon 位宽如何修改?
TGao
Hi 您好,
在C10GX中的DDR3 IP 设置中avalon 位宽如何修改?
Ted​
NurAida_A_Intel
Hi Ted,
Thank you for the Quartus version confirmation.
The parameter is actually hidden in the Quartus. Under the "Controller" tab, you need to right click the EMIF GUI and click "Show Hidden Parameter" as shown below
Then just scroll down and you will be able to see the "Maximum avalon-mm burst length" setting as per highlighted in yellow.
Kindly let me know if you still unable to see it.
Aida
NurAida_A_Intel
Dear Ted,
Thank you for joining this Intel Community.
Unfortunately, there is no other option as the avalon width is depend on the controller (I believed in your case is DDR3L) data width. You need to either increase or decrease your DDR3L data width in order to have your required avalon input data width.
I am so sorry for the inconvenience caused.
Aida
TGao
Hi Aida,
Thanks for your reply.
Yes, It;s DDR3L. and Maybe I describe not clearly, the width I mean is "Maxmun avalon-mm burst length" . This is easily changed in lpddr2 but I can't find in DDR3L .
Ted​
NurAida_A_Intel
Hello Ted,
May I know which Quartus version are you using?
Aida
TGao
HI Aida,
Quartus 18.1 Pro. Thanks
Ted
NurAida_A_Intel
Hi Ted,
Aida
TGao
Hi Aida,
It's Great, Thanks for your Help!
Ted​
