客户采用的1SM21 UF55这个型号,在PDN中没有找到,参考的demo板是1SM21 UF43的设计
May I know the full opn for the FPGA
1SM21BEU2F55E1VG
************************************************** DISCLAIMER: This email is for the use of the intended recipient(s) only. If you have received this email in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not keep, use, disclose, copy or distribute this email without the author’s prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. The information contained in this communication may be confidential and may be subject to the attorney-client privilege. If you are the intended recipient and you do not wish to receive similar electronic messages from us in future then please respond to the sender to this effect. **************************************************
Hi ,
I am kindly requesting , reply on forum instead of Email , because the forum is publicly view.
Hi ,
I verified the pdn , the opn is not mentioned on that , from the description what I understood is that you need to remove 470UF, May I know how you have arrived the value , if the 470uf capacitor value is working fine why you needed to remove.
From my understanding if it is taking more space , can it be changed by a capacitor bank
Hi ,
Kindly let me know if you need further assistance
