I'm implementing 10GbE on a Stratix 10 GX device (currently using the DK-DEV-1SGX-H-A development kit) and had a few questions with regard on how to go about this.
Basic system information:
- Will be part of a much larger system/project
- 10G only implementation (will not be using any other speed 1G, 25G, etc.)
- 1 channel
- MAC + PCS + PMA
- H-tile transceiver
- Will need to be supported for the next 10+ years
Questions:
1. For a new system is there any general recommendation on which IP to use, either the 25G Ethernet or a combination of LLE 10G MAC and 10GBASE-R PHY?
2. It doesn't seem like it, but is it possible configure the 25G Ethernet IP in such a way that it would start in, or only operate in, 10G mode?
3. Is the main purpose of the 10G/25G rate switching (in the 25G Ethernet IP) to allow rate switching on the fly, or is this also intended to replace the 10G MAC + PHY and allow backwards compatibility with 10GbE systems?
Any input/information on this would be greatly appreciated.
Cheers
HI,
Pls see my comment below
- Since you are just interested with 10G application then it make more sense for you to consider either
- LLE 10G MAC + 10GBASE-R PHY
- or LLE 10G MAC + 1G/2.5G/5G/10G Multi-rate Ethernet PHY
2. It doesn't seem like it, but is it possible configure the 25G Ethernet IP in such a way that it would start in, or only operate in, 10G mode ?
- Unlikely as this IP is meant for 25G application with additional option to downgrade to 10G. So, It will start with 25G
3. Is the main purpose of the 10G/25G rate switching (in the 25G Ethernet IP) to allow rate switching on the fly, or is this also intended to replace the 10G MAC + PHY and allow backwards compatibility with 10GbE systems ?
- The rate switching option allow on the fly speed change via the reconfiguration process change as shown in example design link
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-s10-25gbe.pdf
- I won't say replacement but think of it like next generation Ethernet IP solution that able to support till 25G but at the same time still preserve backwards compatibility with 10GbE systems
dlim
HI,
dlim
Hi @Deshi_Intel,
Thanks for the response, and answering all of my questions, it's definitely appreciated.
Your responses are in-line with my initial assumptions, so I'm glad that my understanding was on the right track.
Does this also mean there would be no intention of discontinuing support for the LLE 10G MAC + 10GBASE-R PHY in the next 10 years? I understand that it is quite a while away, so it is very difficult to know for sure, but this will be fairly important for the project.
Cheers
Intel won't be able to guarantee any IP offer will last for how long as it's actually depend on market demand and supply dynamic.
Intel marketing team will evaluate the IP solution annually to decide whether to continue sustain it or EOL it. The judgement is purely base on business call.
I am sorry this Intel forum community is meant to address technical enquiry while business justification is out of my control.
Perhaps you can contact your local sales distributor to see if they can give you better answer from business support perspective
dlim
@Deshi_Intel, thanks again for the response.
I figured this might be the case, as with most things from a business perspective, but it doesn't hurt to ask.
Either way, I really appreciate the additional feedback and input.
Cheers
You are welcome !
Alright, I am setting this case to closure.
Feel free to post new forum thread if you still have enquiry in future.
dlim
