10M02SCE144C8G
Grantwt
Can someone send me a link to where I can find the footprint and pin connection for the 10M02SCE144C8G, as I need to do a PCB layout and I need to know what pins to connect up.
AminT_Intel
Sorry to let you know that Intel FPGA do not provide support for PCB footprint symbols for FPGA and CPLD device families, similar to configuration devices.
However, we will continue the support by providing the schematic symbol which you can download from the link below. You could have the schematic symbol in .olb format from the link below:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/board-layout-test/pcb/pcb-cadence.html
Here is the document for Intel® MAX® 10 FPGA Device Family Pin Connection Guidelineshttps://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
Thank you.
Grantwt
Here what am looking for:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max7k/archives/epm7128e.pdf
But for the 10M02SCE144C8G, so therefore I am now using the EPM7128 as I have mode up the required PCB foot print, and  it is able to work with 5v TTL directly, which is a big advantage in this application. As for the *.olb file, all I get is unknown file format and it has no use to me for PCB development work.
mrblack
Looking to verify if the following marking is correct for this part number.
mrblack
Please disregard.  I was able to find out.
