6310 Discussions
10M02SCE144I7G programming through USB blasters fails
JRe2s
Hello team,
the programming execution fails at 4%. Attached is the Quartus II project, a screenshot of the programming execution and the schematics of the FPGA. The programming file is the *.pof.
Do you see any mistakes?
Jochen
Fakhrul
Since you have solved your issues, I’ll transition this thread to community support. If you have any new questions, feel free to open a new thread to receive assistance from Intel experts. Otherwise, the community members will continue to help you here.
Thank you for your engagement!
Fakhrul
sstrell
Have you tried direct programming with a .sof instead of the .pof?
JRe2s
Hello team,
it seems that a programming once with a *.sof file and subsequent programming with a *.pof file with the check box "Enable real-time ISP to allow programming when available" avrivated is successfull. Can you  confirm that?
Jochen
Fakhrul
Hi JRe2s,
Yes, when programming a MAX 10 FPGA, you typically need to first program the "SOF" file, which essentially acts as a bootloader that allows you to then program the full configuration data onto the device using the on-chip flash memory. Check the Intel® MAX® 10 FPGA Configuration User Guide for more details. Additionally, when you enable this real-time ISP, it is a slow mode. In certain situation, we would suggest to enable it as a workaround to overcome the error.
Fakhrul
Fakhrul
Fakhrul
