6266 Discussions
10M02SCE144I7G programming through USB blasters fails
JRe2s
Hello team,
the programming execution fails at 4%. Attached is the Quartus II project, a screenshot of the programming execution and the schematics of the FPGA. The programming file is the *.pof.
Do you see any mistakes?
Jochen
sstrell
Have you tried direct programming with a .sof instead of the .pof?
JRe2s
Hello team,
it seems that a programming once with a *.sof file and subsequent programming with a *.pof file with the check box "Enable real-time ISP to allow programming when available" avrivated is successfull. Can you  confirm that?
Jochen
