Dear Team,
We are trying to load the logic into 10M04DAF256I7G( Max 10 ) in .sof format, FPGA is responding.
But if we try to load in .pof format there is no response from FPGA.
Can you please help us how to resolve this issue
Thank you for contacting Intel community.
By not able to program .pof, does this happened at stage where you are programming it using Quartus ? or boot up?
Is there any error message?
Aiman
Thanks for your inputs actually .pof is working fine after giving pullup at config done pin.
Now we are facing below issue,
For bank 1B , 2.5V supply is given, that means all IOs from bank 1B will operate at 2.5V. But if we give 3.3V signal on this bank 1B IO pins what may be happens.
is there any protection diodes will be there internally or any damage will be happening to the bank?
Radhakrishnasai V
Hi Radhakrishnasai
You have to follow the requirement in Table 4 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf base on your IO standard, else you might be facing functionality issue.
Eng Wei
Hi Radhakrishnasai
Since we don't receive any feedback to the thread, we will transition the thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
