Hi
Hi Abishek
The analog input pins support single-ended and unipolar measurements. You would not sample the negative voltage using Max 10 ADC block.
You can refer to Analog input voltage of Table 34 and Table 35 based on your device type in
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
You can refer to document below for VCCIO1A and VCCIO1B connection based on your device types:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
Eng Wei
Hi Abishek
Since there's no response from you to the previous reply that have been provided, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
