5694 Discussions
16353 : Expected the max10 device at index 1 to be of type analog, but detected device of type invalid instead. (EMERGENCY)
ocan
I have a problem by programming .pof file But I programmed .sof file succesfully. I don t understand the operation.
The error is 16353 : Expected the max10 device at index 1 to be of type analog, but detected device of type invalid instead.
Can u help please?
Thank u very much ....
YuanLi_S_Intel
Hi Omer,
May i know are you using our development kit? Can you try to change the TCK frequency to 6MHz and have all the switches back to default position?
Thank You.
ocan
​Hi Batman,
 I can use  MAX10 10M08SAU169I7G. I tried to change the TCK frequency to 6MHz but I said that programming .sof  file and not programming .pof file.
Thanks for reply .
YuanLi_S_Intel
Have you tried to program the POF using the flow as stated in user guide?
https://www.intel.cn/content/dam/altera-www/global/zh_CN/pdfs/literature/hb/max-10/ug_m10_config.pdf
Thank You
