6310 Discussions
40-pin GPIO to Breadboard
Hello all,
Does anyone know a good way to connect the 40-pin GPIO sockets on the DE2-115 or SoCKit or HSMC/GPIO expansion card to a solderless breadboard?
By good way I mean a way I can just order an appropriate part (Cable, connector, whatever) that will connect the board to the breadboard without having to create much if anything myself.
Thanks!
EDIT: See thread below for the solution.
--- Quote Start ---
Hello all,
Thanks!
--- Quote End ---
Not sure If I am allowed to post sources, but this is what I am using
with my DE-nano (while waiting for an DE1-SOC to be back in stock):
http://www.technologicalarts.ca
IDC Ribbon Cable-to-breadboard adapter
40-pin Part number: ADIDC40-M
Benoit
somehow, my response to you never appeared.
I found a cie who does sell 40 pins IDC to bread board sockets
That you can use with a 40 pins flat cable.
I use this with my DE NANO.
I will post the info once this post appears (I am a new user)...
Ben
The part I am using is:
ADIDC40-M
Sold by technologicalart
They do not sell the cable. I got the cable from eBay
It'd you want the actual websites, send me a PM.
Ben
Thank you! I cannot send PMs but I will google around for this. I appreciate the pointer.
--- Quote Start ---
--- Quote End ---
Ok,
Here is the link....
http://www.technologicalarts.ca/shop/store/details/250/56/adapters/ribbon-cable/idc-ribbon-cable-to-breadboard-adapter,-40-pin.html
There must be other vendors too..
Benoit
Just tried to post the direct url, no joy
But just a Google search should do the trick.
There must be other sources to. But I could not find one for 40 pins
Spammers are poisoning forums, as it drives moderators to become
Extremely cautious....
Ben
Found it. Ordered several. Great pointer. Shame the moderator won't allow a link because I looked for days before posting and giving up and you had exactly the right thing. Thanks again!
Glad it solved your issue.
Maybe you should edit your initial post and mark this thread as [SOLVED]
Ben
Did that. Thanks for the suggestion.
