6266 Discussions
5CEBA7F27C8N pin information VREFB8AN0
CG123
Hello Intel Team ,
We are not using following pins in our application.
VREFB8AN0
VREFB7AN0
VREFB5AN0
VREFB5BN0
VREFB4AN0
VREFB3AN0
VREFB3BN0
VREFB6AN0
If I connected those pins to +3.3V then what will be the current consumption in those pins.
FvM
presume you noticed that VREFxxx input current isn't explicitely specified in datasheet. Thus I won't expect an official answer.
The pins are routed to a number of differenlial receivers inputs, I believe it's winthin  I/O Pin Leakage Current specifications (+/- 30 uA).
What's the problem behind your question? If you worry about possible VREF current consumption, why not connect it to GND?
Frank
AqidAyman_Intel
Yes, Frank is correct. There is mentioned in the Pin Connection Guidelines that if the VREF pins are not used, you should connect them to either the VCCIO in the bank in which the pin resides or GND.
