5CSEBA2U23C7SN
CTLIM
Can someone please share me failure analysis request link?
We are having problem with below part where the signal "DIFFIO_TX_B41N/RZQ_0" point with the "GND” point ohm value not able to get 15megaohm as per normal part so would like to know the reason.
MPN: 5CSEBA2U23C7SN
CT
Zawani_M_Intel
Thank you for contacting Intel FPGA Community Forum.
Please be noted that we requires details information to understand further your issue. Please help to answer questions below in order for us to better understand your position.
1. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
2. What is the failure symptom? Please elaborate the failure symptom in detail.
3. When did the failure happen? How did you discover the failure?
4. How did you determine the failure? Please elaborate the procedures.
5. Does the failure unit ever working before failure?
Thank you!
Wani
CTLIM
Please find my reply in blue.
- Total defect is 12pcs out of 5272pcs build.
- It failed under test parameter SHORT NAIL- 3,596 during ICT test.
- This failure detected during ICT testing, after debugging they found the IC signal "DIFFIO_TX_B41N/RZQ_0" point with the "GND” point ohm value does not match.
- By measuring the resistance value on trace and compare between good board.
- ICT testing is our first testing station in process flow and the signal test parameter is first step to check the grounding before power up the board.
CT
Zawani_M_Intel
Dear CT,
As some confidential info is required, we will continue support your case privately.
Please check your inbox for further support.
Thank you!
Wani
givememessage
New Contributor II
In response to the 5CSEBA2U23C7SN issue, our engineers have established a group chat to discuss this issue. If you are interested, please send it to me.
