For your information, 5M1270ZF324C4N is 324-Pin FineLine Ball-Grid Array (FBGA). Hence, the tray size is 19mmx19mm (Daewon 12U-1919-GXX). Normally, it is found as live bug orientation. Kindly refer to AN71 (page 4 and 10) for further information.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an071.pdf
Aqid
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Please help to check is it all below MPN have same tray size, tray Matrix Row-Column & same orientation ?
Is it all below MPN are 324-Pin FineLine Ball-Grid Array (FBGA) with tray size 19mmx19mm (Daewon 12U-1919-GXX), tray matrix row-column ( 6x14)?
5M1270ZF324C5N |
5M1270ZF324I5N |
5M2210ZF324I5N |
5M1270ZF324C4N |
5M2210ZF324C5N |
5M2210ZF324C4N |
