5SGXMA5K3F40C2LN
WXu001
​For this  parts, through schematic confirm GA1T. AR10 & AR13 to GND should be greater than 200OHM ,Use multimeter measured about 60OHM.
Deshi_Intel
Are you requesting failure analysis support for this suspected failure FPGA device here ?
Can you explain further on the FPGA failure symptom ?
  • How many failure FPGA devices here ?
  • Is this new prototype project or mature production project ?
  • Kindly clarify on the FPGA failure pins location again.
    • GA1T doesn't look like FPGA pin location. What's GA1T ?
    • Does AR10 and AR13 refer to FPGA pin location and you are facing pin short condition here ?
  • Under what kind of production testing that you observe this failure ?
dlim
Deshi_Intel
HI,
I have not hear back from you hence setting this case to closure.
Feel free to post new forum thread if you would like to resume the support discussion in future.
dlim
