AD/DA Data conversion card
I need to connect AD/DA Data Conversion card on my DE2-115 board using HSMC connector. I need the pinout for both boards for the same.
In the DE2-115 user manual I can find the FPGA pin names against the signal names of HSMC connector but can not understand the pin numbers of the connector.
and in the AD/DA conversion card reference manual pinouts are given for Cyclone III and Stratix III boards but not for this particular Cyclone IV board.
Link for the card I want to use : https://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=73&no=360&partno=2
Any help is appreciated.
Thanks!
I see HSMC pin assignment clearly documented in FPGA- and extension-board schematics.
A problem with HSMC pin numbers is caused by the fact that the ADDA card (at least the previous version) are using a connector with additional pins in the LVDS Bank 1, resulting in a total of 180 versus 160 signal pins. Both connectors are plug-in compatible as far as I understand, but numbers are different,
