6330 Discussions
AN483, tse_ref_design, error in analaysis&synthesis after sopc system generation
Hello together,
I downloaded the tse reference design (AN483). I use Quartus II 9.1.2.
When i open the project and run "Analysis & Synthesis" i get no errors and the green tick appears. But when i run the process after i opened SOPC Builder and clicked "Generate", some errors occur:
--- Quote Start ---
Error: Node instance "altera_tse_mac_pcs_pma_inst" instantiated with unknown parameter "ENABLE_EXTENDED_STAT_REG"
Error: Node instance "altera_tse_mac_pcs_pma_inst" instantiated with unknown parameter "SYNCHRONIZER_DEPTH"
Error: Node instance "altera_tse_mac_pcs_pma_inst" instantiated with unknown parameter "TRANSCEIVER_OPTION"
Error: Node instance "altera_tse_mac_pcs_pma_inst" instantiated with unknown parameter "ENABLE_ALT_RECONFIG"
Error: Can't elaborate user hierarchy "tse_ref_design:tse_ref_design_inst|altera_ethernet:the_altera_ethernet|altera_tse_mac_pcs_pma:altera_tse_mac_pcs_pma_inst"
Error: Quartus II Analysis & Synthesis was unsuccessful. 5 errors, 3 warnings
--- Quote End ---
What is going wrong?
Greets Florian
another question:
how to run the simulation/testbench provided in tse_ref_design? I am new to Altera tools. I have Modelsim SE 6.4c.
Florian,
I just ran into a similar issue running Quartus 8.0. When I try to compile, I get the error:
Were you able to resolve this issue?
I've run into similar problems with PCIe core. I was able to solve this problem by deleting all files that are generated by SoPC builder.
It is possible that some files are not re-generated when the SoPC builder see that they are present. There are changes between versions of core (and Quartus) that can lead to these errors.
zizka,
Thanks. I tried removing all SOPC files and regenerated. This was enough to get me over the issue.
