Hi
I would like to know more detail about RMII interface timing.
I wrote 2 quiestions below.
(I send 50MHz CLK to HPS EMAC as a REF_CLK from phy chip.)
1)Do you have any reguration for R_CLK?
For example frequency,duty ,rise time ,falltime.
If you have,please show me reguration with voltage level.
I could confirm on datasheet only TX_CLK reguration but couldnt find about RX_CLK.
2)Which edge the HPS EMAC ratched RX_D/RX_CTL signals.
I added figure to support my poor English.
Hi ,
If I am not wrong the above diagram is from from the below user guide and the pins used in transceiver.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an-a10-soc-device-design-guidelines.pdf
Page no: 50
Hi
YES.page48 Figure 10. is what i showed in added figure.
