5925 Discussions
ASI OpenCore IP Compilation Error
I try to compile the cvdb_demo.qpf QuartusII project with the ASI OpenCore IP. I got the following error messages:
Error: Node instance "asi_megacore_top_inst" instantiates undefined entity "asi_megacore_top" File: ../asi/source/mc_build/asi_rx.v Line: 65
It seems to me that the asi_megacore_top is not defined in any .v file.
Also this project is for QFP device. Can it be compiled for CycloneIII device?
Please help.
David
i'm not familiar with this design, is there an SOPC Builder system you can regenerate before you compile?
According to the user guide, http://www.altera.com/literature/ug/ug_asi.pdf, Cyclone III should be supported.
Thank you for your reply. But I need a working example for a jump start. The example code comes with the installed IP seems not working.
David
