I'm uising arria V device in my project, a pair of LVDS pins are used in my design, which are configured as output. It always cannot work well, and by using OSC I watched the output waveform of LVDS port, it was quite strange, the pos and neg pins are the same, and even the Vocm and Vdm is incorrect, refer the below image. I'm sure the pin configuration is accurate, and the pins is not demaged since I tried another LVDS pin. So, whats could be the reason? thanks
- Tags:
- lvds
Can you share the sch and output interface connected to the LVDS output ?
Thanks ,
Sree
Hi, is there any update?
Hello,, sorry for delay in response.
There should be common mode voltage in the LVDS bus which i didnt see in the graph you sent me.
can you check the LVDS std is set correctly ?
Thank you,
Sree
Hi, how is the thing going on? thanks
Sorry , I am not sure what is missing here.
Can you check is IO is not open ended ? Pretty much looks like other side is open.
Is there any external termination ?
Thank you ,
regards,
Sree
This thread will be transitioned to community support. If your question is not addressed yet or you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
