5540 Discussions
Access config flash on Stratix 10 DX development kit
alexforencich
The Stratix 10 DX development kit has a QSPI configuration flash.  Unfortunately, this flash chip is not connected to the Stratix 10 FPGA, it sits behind a MAX 10 FPGA that presumably runs the PFL IP.  (this is in contrast to other development boards such as the Stratix 10 MX dev kit, which directly connects the QSPI flash to the Stratix 10 MX FPGA)
I want to be able to write to the config flash from the Stratix 10 FPGA (so I can update the firmeware in-band over PCIe).  How do I do this?  Or is it impossible without modifying the configuration running on the MAX 10?
Ash_R_Intel
Hi Alex,
Please note that QSPI is connected to the MAX 10 device only, hence you cannot configure it directly from S10 device.
Please refer Figure 29 of the user guide:
https://www.intel.com/content/www/us/en/programmable/documentation/cko1566842257868.html#sri1567705138773
It seems that SW33.2 can help configure the flash using PCIe.
Let us know if you are able to proceed with this.
Regards.
alexforencich
It's unclear what that switch does.  Presumably it has something to do with the JTAG pins on the PCIe edge connector?  It's unclear if those pins can really be used for anything on most motherboards.  What I need to be able to do is access the flash chip somehow from the Stratix 10 FPGA, in this case this would be from a userspace application that interfaces with the Stratix 10 via the normal PCIe link.
Ash_R_Intel
As mentioned earlier, the QSPI cannot be accessed directly by S10 device. Hope this answers your query. Closing the case for now.
Regards.
