I am trying to Access the PIO IP instantiated on the FPGA fabric side from the VxWorks Application to toggle LED on the board.
I did not find any example design/reference to understand how it works. Could you please help me understand how it works and how we target PIO memory address from the application.
Also, where do we find the drivers of the FPGA IP cores? If i am not wrong it is at path: installation_folder>20.3>ip>altera>sopc_builder_ip>altera_avalon_pio.
But when I do it this way I found below error messages.
Kindly help me understand if i am missing something here.
Sukesh.Pednekar
Hi Sukesh,
This is duplicated case. This same query has been answered on the IPS case and email id.
Regarding the example for PIO core with HWLIB. There is some reference given with the NIOS II and PIO in the below document.
https://www.intel.com/programmable/technical-pdfs/683525.pdf
It seems we don’t have driver for FPGA IP’s with the HPS with the Baremetal/HWLIB.
You can find the available and latest driver list with the Baremetal/HWLIB on https://github.com/altera-opensource/intel-socfpga-hwlib/tree/master/examples/A10
But if you are going to use the linux, then yes we do have PIO driver in linux and same we have showed you using the LED/Button example from the GSRD/GHRD.
https://www.rocketboards.org/foswiki/Documentation/LinuxDrivers
With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Hi Sukesh, we would like to inform you that we are routing your query to the dedicated team for further assistance.
Hi Sukesh,
Thank you.
Tiwari
