6387 Discussions
Accessing SDM SPI Flash via HPS fails (MBOX_RESP_PUF_ACCCES_FAILED) on Agilex 7 FPGA
Kiebach
Using u-boot to request access to SPI flash controller fails with the error message: MBOX_RESP_PUF_ACCCES_FAILED (0x80) /*Invalid license for IID registration*/.
This error message is returned to the HPS from the SDM using the SDM mailbox.
For reference, we have Agilex™ 7 FPGA I-Series Development Kit (ES1 2x R-Tile & 1x F-Tile) DK-DEV-AGI027R1BES (Power Solution 1) AGIB027R29A1E2VR3.
Any help in understanding the MBOX_RESP_PUF_ACCCES_FAILED error code and how to resolve would be greatly appreciated.
Kiebach
Kiebach
I've been able to use the SDM mailbox to get IDCODE, CHIPID, USERCODE, VOLTAGEs, TEMPERATUREs and CONFIG_STATUS information.  Works great.
Accessing the QSPI is not working, and I don't know why.
QSPI_OPEN works.
QSPI_SET_CS results in MBOX_RESP_PUF_ACCCES_FAILED = 0x80, /* Invalid license for IID registration */
Doesn't matter which nCSO value, all four of them get the same failure.
Does anyone know how to resolve this error code?
PS - Reference the Mailbox Client Intel FPGA IPs User Guide 683290 2024.07.08.
Fakhrul
Hi Kiebach,
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
