This site shows the memory map of the Agilex 7 HPS:
When I read the SPI Master registers, I get only ZEROs?!? What is amiss?!?
CTRLR0...........00000000
CTRLR1...........00000000
SSIENR...........00000000
MWCR.............00000000
SER..............00000000
BAUDR ...........00000000
TXFTLR...........00000000
RXFTLR...........00000000
TXFLR............00000000
RXFLR............00000000
SR...............00000000
IMR..............00000000
ISR..............00000000
RISR.............00000000
TXOICR...........00000000
RXOICR...........00000000
RXUICR...........00000000
MSTICR...........00000000
ICR..............00000000
DMACR............00000000
DMATDLR..........00000000
DMARDLR..........00000000
IDR..............00000000
SSI_VERSION_ID...00000000
DR0..............00000000
DR1..............00000000
DR2..............00000000
DR3..............00000000
DR4..............00000000
DR5..............00000000
DR6..............00000000
DR7..............00000000
DR8..............00000000
DR9..............00000000
DR10.............00000000
DR11.............00000000
DR12.............00000000
DR13.............00000000
DR14.............00000000
DR15.............00000000
DR16.............00000000
DR17.............00000000
DR18.............00000000
DR19.............00000000
DR20.............00000000
DR21.............00000000
DR22.............00000000
DR23.............00000000
DR24.............00000000
DR25.............00000000
DR26.............00000000
DR27.............00000000
DR28.............00000000
DR29.............00000000
DR30.............00000000
DR31.............00000000
DR32.............00000000
DR33.............00000000
DR34.............00000000
DR35.............00000000
RX_SAMPLE_DLY....00000000
RSVD_1...........00000000
RSVD_2...........00000000
Note that I am using a Agilex™ 7 FPGA I-Series Development Kit (ES1 2x R-Tile & 1x F-Tile) DK-DEV-AGI027R1BES (Power Solution 1) AGIB027R29A1E2VR3.
The HPS TRM has a section "B.2. Taking Ownership of Quad SPI Controller" where it says that the bootloader takes control of the SPI Controller from the SDM. This section is vague and does not supply any specific details as to how this is done. My next step will be to study u-boot to see how this is accomplished. If anyone at INTEL can provide assistance it would be appreciated...
MBOX_RESP_PUF_ACCCES_FAILED = 0x80,
Hi
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Jingyang, Teh
Hi
Usually for the HPS SPI. You could interface with the SPI in the linux rootfs /dev directory.
You would not need to interact with the SPI using the registers.
Jingyang, Teh
Hi
Any update on this case?
Jingyang, Teh
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
